Hello
I would like connect printer to est-3. I try connection based
on manual from printer est pt-1 but printer not working.
What is proper connection and setup of printer.
Peter
printer connection
Re: printer connection
Hi Peter
-check that the 3-RS232 optional card is installed correctly
-check the proper configuration to port1 port2 in SDU.
regards...
regards...
peter wrote:Hello
Peter
What is proper setup of the sdu?
in cabinet configuration
-PORTS:
-port 1 or 2 type PRINTER OR SUPERVISED PRINTER (same as PT1 connection)
-baud rate (same as PT1 settings)
save project
regards...
-PORTS:
save project
regards...
PT Series Printers
- est3-est2-qs3100989_R1_PT_Series_Printers.pdf
- (304.83 KiB) Downloaded 1337 times
Do you have the pin out data for the DB9 connector for capturing info to a laptop, and is the hyperterm settings the same as for the printer on the attached file.
Dan
Dan
