Honeywell W247 Fire Alarm panel
jm2014
Post by jm2014 »
Does anyone here have any wiring diagrams or schematics to an old Honeywell W247 fire alarm panel? It's an older system installed around 1969 or 1970 and has coded pull stations for each zone. The coded pull stations have a circuit for Normally open pull stations and heat detectors. I have attached a file of the panel in question. Thanks!
mimi_muscovy
Re: Honeywell W247 Fire Alarm panel
Post by mimi_muscovy »
Hello there, I do not have any manual for this panel, but I have found some Diagrams for it. Hopefully this helped you or someone else.
W247G.zip
(715.65 KiB) Downloaded 24 times
