hi all
I am an expert in software protection reverse engineering.
I want to help solve your EST3 or EST4 problems
If you have a real dongle I can do it for you emulator for windows 11 x64
my telegram is @lordofthedongles
i need to buy the dongle for EST3
dears all,
kindly, i need to buy the dongle key for est3 because i lost my one.
Dear lts-maroc;
I will appreciate if you send to my email(omid_raha7@yahoo.com) "https://rapidshare.com/#!download|434p1 ... up2012.zip"
Best Regards
Best Regards
Re: i need to buy the dongle for EST3
DEAR ENGBADDALY:
THIS HASPKEY WORTHS 500 DOLLARS BUT YOU NEED TO CONTACT YOUR UTC PROVIDER TO GET ONE, FIRST OF ALL YOU HAVE TO PROVE YOU ARE CERTIFIED, IF YOU GOT YOUR HASPKEY WORKING FOR A THIRD COMPANY YOU NEED TO ASK THE IF THEY CAN GET A NEW ONE FOR YOU IS CHEAPER, IF NOT YOU NEED TO RECERTIFY, I HAVE LOST MINE TOO, AND I WASY NOT ABLE TO BUY A NEW ONE, I HAVE TAKEN A RECERTIFICATION COURSE AGAIN IN MEXICO, TO GET A NEW ONE, TOTAL SPENT 3500 DOLLARS.
Dear Friends,
I have a solution for you, to avoid any lose of your HASP key, you can dump the key with dongle services, or get a cracked software that can dump it and emulate it when you don't need to use the dongle key.
I leave the company that i worked for, and i use it for my own projects, for maintenances.
Good Luck.
Yassine
Good Luck.
Yassine
These File i will join to you contains the file cracked, but need hat you follow these instructions, it works as EST3 Software Key:
1- i tested with XP system
2- Return the date of the system to a Valid from 26/Aug/2010 to 2/Sep/2010, you choose one date .
3- Open the "USB Dongle Backup and Recovery 2012", go the the tab "Driver", then "Install Driver", verify in this tab, in "Driver Statuts "that the driver is installed.
4- Go to the "Emulator" Tab then "Start Service", wait untill it started.
5- Load dump, witch is "1A4B27EB.dng".
6-run your application.
7-Enjoy.
If you want to install a new application of 3-SDU, you have just to repeat from 1---5 , then nstall the application, the PIN code is "EDF5856EEF3CEB93" , please the date is so important to change it before start the operation.
Please go to these URL to download the files: https://rapidshare.com/files/3728587953/1A4B27EB.dng
https://rapidshare.com/files/381519616/ ... up2012.zip
Enjoy.
7-Enjoy.
Enjoy.
The download files are not found.
could you email them to me - leogerst@hotmail.com
Dear leo,
you're right the file isn't found, so the new link is : https://rapidshare.com/#!download|434p1 ... p|2145|0|0
I keep getting all sorts of warnings from my system.
Has anyone tried this thing?
alpha bravo wrote:I keep getting all sorts of warnings from my system.
hi the trouble starts when you change the date in your system, i recommend to install a virtual machine to run this emulator.
the files and emulator is 100% safe but some antivirus may popup a warning.
regards...
