FYI..... I had to make a minor program change to 2 Quickstart Panels. The next day, I got a report of 2 Missed Timer Tests on these 2 panels. Originally, the 2 panels had v1.8. When I loaded, I updated to v2.5. I put a Butt Set on and monitored the system/Dialer while forcing in a timer test/Trouble signal. The panel would go off hook and just sit there and not Dial out anywhere. Long Story Short......I reloaded the 2 panels with the same database , BUT with Version 1.8 and not 2.5 , and the Panel started Dialing / Sending out signals again.
I emailed tech support in regards to this. I will update when I get an answer....Most Likely, Its going to be another deal whereas ... If you have a CPU with Hardware V1.0 , and a DLD with 1.2 , AND you update your Firmware from 1.8 to 2.5 , stuff aint gonna work apparently!
Quickstart Dialer Issue...
- ----- F i r e -----
- ↳ MANUALS
- ↳ NPFA72/70
- ↳ UTC - EST
- ↳ EST3
- ↳ EST4
- ↳ EST3 Rules
- ↳ I/O panels
- ↳ QuickStart
- ↳ FireWorks
- ↳ EST2
- ↳ Misc/Devices
- ↳ IRC3
- ↳ Notifier
- ↳ ONYXWorks
- ↳ FireLite
- ↳ SilentKnight
- ↳ Ademco - V32FB
- ↳ Fire Alarm Inspection
- ↳ Other FACP
- ↳ Duct Detectors
- ↳ Radio Communicator
- ↳ Hardware
- ↳ Honeywell - Winpak
- ↳ honeywellaccess.com
- ↳ HoneyWell - ProWatch
- ↳ HoneyWellIntegrated.com
- ↳ Kantech
- ↳ Readers
- ↳ hidglobal.com
- ↳ Card Access Systems
- ↳ Credentials
- ---- Other Systems ----
- Heliostat
- ↳ Heliostat
- ↳ heliostat.us
