EST3 - POWER SUPPLYS PPS/M BPS/M BBC/M
PPS/M - Panel Power Supply. This is just the main Power supply for the panel
BPS/M - Booster Power Supply.
it does not charge batteries, you need to run jumpers between the PPS/M and BPS/M battery terminals so the BPS/M has batteries.
If you want to upgrade this PS to charge batteries buy 3-BBCMON
BBC/M - Booster Battery Charger.
This needs it own batteries (same Amp Hour as the PPS/M)
Why do you have a BBC or BPS, blame it on the (EST's SYSTEM BUILDER)
Few people change what the SYSTEM BUILDER spits out
I like the BBC/M when a second supply is need because the batteries can be a like more normal in size.
ie. one pair of 60 amp hour - or - two pair of 30 amp hour
3-PPS/M Primary Power Supply with Local Rail Module. 120V 50/60 Hz. Takes one Footprint in wallbox and one local Rail module space. Supports one user interface module. Provides 7 A at nominal 24V dc. Provides two 3.5 Amp auxiliary power limited outputs. Charges up to 65 Amp Hour Batteries. $1,110.00
3-BBC/M Booster Power Supply / Charger with Local Rail Module. 120V 50/60 Hz. Takes one Footprint in wallbox and one local Rail module space. Supports one user interface module. Provides 7 amp at nominal 24V dc. Provides two 3.5 Amp auxiliary power limited outputs. Charges 65 AH batteries.$1,200.00
3-BPS/M Booster Power Supply with Local Rail Module. 120V 50/60 Hz. Takes one Footprint in wallbox and one local Rail module space. Supports one user interface module. Provides 7 amp at nominal 24V dc. Provides two 3.5 Amp auxiliary power limited outputs.$1,156.00
3-BBCMON Booster Power Supply / Charger Local Rail Module ONLY. Upgrades 3-BPS/M to 3-BCC/M. Replaces existing 3-BPSMON. Supports one user interface module. Charges 65 AH batteries $650.00
