Hi All,
Im newbie here. Anyone encounter this problem POWER SUPPLY FAILURE. I have two panel serve as a annunciator panel in the network and these two panel now showing power supply failure. Once i reset the panel it will not appear for two days. Thanks
Re: POWER SUPPLY FAILURE
It means the circuitry in the power supply is failing, You need to replace the power supply.
Thanks. Yeah i end up changing the power supply and it goes well.
