QS - pseudo - PS6 card pseudo points
All DLD pseudo point are card 15
This list is in - online Help->Programming reference->Pseudo points->
1:15:000 - Communications - A trouble response when the PS6 card stops communicating
1:15:001 - Battery Charger Fault, Internal Fault - A trouble response when the battery circuit charging voltage falls below 20.4 VDC
1:15:002 - Battery Wiring or Battery Fault, Internal Fault - A trouble response when there is an open in the battery wiring or if the battery voltage falls below 20.4 VDC
1:15:003 - Aux Power 1/2 Shorted, Internal Fault - A trouble response when the AUX1 or AUX2 power output circuit is shorted
1:15:005 - Aux Power 3 Shorted, Internal Fault - A trouble response when the AUX3 power output circuit is shorted
1:15:006 - Smoke Power Shorted, Internal Fault - A trouble response when the smoke/accessory power output circuit is shorted
1:15:007 - Primary AC Power Failure, Internal Fault - A trouble response when primary power is lost or is very low
1:15:008 - Excessive Battery Current, Internal Fault - A trouble response when the PS6 detects an over current condition while operating on battery power
1:15:009 - Check System Wiring, Ground Fault - A trouble response when there is a ground fault in the system wiring
1:15:010 - Power Supply Card RAM Fault, Internal Fault - A trouble response when the PS6 card detects an internal memory failure
1:15:011 - Power Supply Card ROM Fault, Internal Fault - A trouble response when the PS6 card detects an internal memory failure
1:15:012 - Power Supply EEPROM Fault, Internal Fault - A trouble response when the PS6 card detects an internal memory failure
