Gamewell CAMWorks and FCI-7100
rondparker
Post by rondparker »
I have CAMWorks and a RJ11 to DB9 cable. Plugging into the onboard RJ11 socket of the FCI-7100 will not allow me to connect.
The manual says I do not need the INI-7100 on a standalone 7100. Any suggestions?
Thank you in advance
FVILLA
Re: Gamewell CAMWorks and FCI-7100
Post by FVILLA »
rondparker wrote: Sun Feb 28, 2021 6:24 pm I have CAMWorks and a RJ11 to DB9 cable. Plugging into the onboard RJ11 socket of the FCI-7100 will not allow me to connect.
hi
can try first with HyperTerminal just to make sure everything is fine these are the parameters:
Bits per second: 9600
Data bits: 8
Parity: None
Stop bits: 1
Flow Control: None
some old firmware versions of 7100 will not connect to the latest version of CAMWorks,
Regards.
rondparker
Thank you. I tried that. I may have to go over the pin outs of the cable I am using. It may be the culprit.
I appreciate your input.
rondparker
Found the cable information with pin outs (attached). All is well
E3 SERIES GAMEWELL-CABLE PROGRAMMER.pdf
(55.45 KiB) Downloaded 791 times
rondparker
Using Camworks I can connect but the "upload' option is not highlighted only download. Any idea why I cannot upload the existing configuration?
FVILLA
Post by FVILLA »
rondparker wrote: Tue May 11, 2021 11:25 am Using Camworks I can connect but the "upload' option is not highlighted only download. Any idea why I cannot upload the existing configuration?
Hi, for the 7100 panels the upload option is on the download page "7100 upload",
just click download to see what I'm talking about...
Regards.
technicalsupp-999
Post by technicalsupp-999 »
CamWorks for E3 S3 7100 FCI Gamewell HoneyWell Panels latest Ver 3.60.003 -DEC 2020
permanent license all options enabled
write me for more info:
technicalsupp-999@hotmail.com
regards
