Installing 2-SDU for EST2 in the same machine for 3-SDU
jjaimevera
Post by jjaimevera »
I'm trying to install the 2-SDU for an EST2 panel with the USB HASP Key and the pin number for 2-SDU in the same machine in where i have installed the 3-SDU for XLS1000 with the HASP key and correct ping.
I have the two keys and the two PIN correct numbers, but wheen i'm trying to install the 2-SDU i'm getting the follow message: Title: Severe, Msg: The PIN number is invalid. Please correct. [OK].
Anyone knows if can coexist the two SDU? or i should format my machine for install again only one SDU.. 2 or 3... for EST2 or for XLS1000.
Or why I have this error PIN, the two PIN's are correct also the two HASP Keys.
Best Regards. Jaime Vera (jjaimevera)
Re: Installing 2-SDU for EST2 in the same machine for 3-SDU
run this program skcheck2.exe from this post - http://www.thealarmtech.com/forum/viewt ... ?f=5&t=627
I think it will answer your question, If not let us know
jjaimevera
I downloaded the application skcheck2.exe for diagnosis to USB key (for 2-SDU).
The message is as follows:
  • Key Existance Test: Passed
    Key Status Test : Failure
    Incorrect password!
    Key Code Test : Failure
    Incorrect password!
    !!!! THIS IS NOT A VALID EST KEY !!!!
it sounds like this is a honeywell key for the XLS1000 panel. which is not going to be able to do the EST2 SDU.
jjaimevera
I think maybe the HASP Key (USB) for EST2 (2-SDU) is damaged, because I tested the HASP Key (LPT) for XLS1000 (3-SDU) and the result is different.
This is the result for the Honeywell HASP Key using the same skcheck2.exe:
    Key Status Test : Passed
    Key Code Test : Passed
    Serial Number : 0017xx
    3-SDU : Enabled
    • > Delete Project
      > Save Project
      > Import Project
      > Export Project
      > Compile Project
      > Download Project
      > Import MicroCode
      > Audio
    2-SDU : NOT Enabled
    RDU : NOT Enabled
    Honeywell RDU : NOT Enabled
    FireWorks : NOT Enabled
    ANA-USA : NOT Enabled
    ACDB : NOT Enabled
    EST Specials : NOT Enabled
    EST DLL : NOT Enabled
    Brand : Honeywell
The results are absolutely different, and of course, still i have the error for the #PIN installing the 2-SDU, and I tried in a clean Win XP-SP1, XP-SP2, XP-SP3 and Win 2003 Server. The error is the same: The #PIN for 2-SDU and the test for the HASP are the same in any OS.
jjaimevera
I got a new HASP Key for 2-SDU/EST2. Everything is working OK.
    Serial Number : 0008xx
    3-SDU : Enabled
    • > Delete Project
      > Save Project
      > Import Project
      > Export Project
      > Compile Project
      > Download Project
      > Import MicroCode
      > Audio
    2-SDU : Enabled
    • > Delete Project
      > Save Project
      > Import Project
      > Export Project
      > Compile Project
      > Download Project
    RDU : NOT Enabled
    ACDB : NOT Enabled
    Brand : Edwards Systems Technology
