EST2 Devices
vectrasoundz
EST2 Devices
Post by vectrasoundz »
I have to convert an EST2 system to IO1000, I'm trained on the IO but unfortunately not on the EST2, is there a way to display the devices programmed into the EST and their labels?
Re: EST2 Devices
the only way to get the serial numbers is through the EST2 SDU program,
you would need to made a new project then upload the SLC loop/info
then connect your computer to the panel''s printer port via Hyperterminal,
remove the SLC line, all devices will go into comm fail, capture the data
find the file in the SDU that has the serial numbers in it.
take the two files and made a nice little Excel file of all the info you will need.
No labels, but the labels are only for your inputs to outputs.
this is an EST2 the inputs to outputs is not a big thing
so you need an EST2 Dongle, good luck
EST2 com port settings
9600-8-E-1
capture the info to a file
