communication problem with ge RAEADER PRM5 EV1
AKA-Casi Rusco, Software-Facility Commander panel-M5/M3000, Cards-PXNplus, 8RP
mechatronix
Post by mechatronix »
I HAVE THE READER CONNECTIVITY PROBLEM WITH GE READER PRM5 EV1 SF2F . I AM CONNECTING THIS READER TO PX-2000 THROUGH A JUNCTION BOX. IT IS NOT READING ANY MIFARE CARD AND GIVES A TRIPLE BEEP AT START UP. SHOULD I UPGRADE THE FIRMWARE OF PX-2000 CONNECTIN THIS READER OR THERE IS ANOTHER WAY TO SOLVE THIS PROBLEM. KINDLY REPLY ME IT'S URGENT.
mechatronix
Re: communication problem with ge RAEADER PRM5 EV1
how could i reprogram the reader i had reader model t-500 which was working with the px-2000. but i have to replace those readers with PRM EV1. BUT IT IS NOT COMMUNICATING what should i do?
The protocol for this reader is not F2F it is wiegand, if you are using a J-box the t-500 are using F2F.
So to get these reader to work with a px-2000 panel you will need a Wiegand to F2F converter also known as a HID interface.
check this post- http://www.thealarmtech.com/forum/viewt ... &hilit=hid
mechatronix
thanks but i have checked the data sheet of the reader the communication type of this reader is F/2f supervised plaese check the attachment.it is written at the back of the reader ''sF2F/o.c.''
DS-EMEA-S1033000.pdf
this is the data sheet of the reader i am trying to communicate
(142.2 KiB) Downloaded 745 times
mechatronix
mechatronix
what is the difference between weigand and f2f , why px 2000 is not supporting prm5 ev how would i know wether it is in weigand mode or f2f
