i need to buy the dongle for EST3
Nirujan
Re: i need to buy the dongle for EST3
Post by Nirujan »
thank you i am waiting for that software...
Nirujan
Post by Nirujan »
lts-maroc wrote:Hi dear,
No cost, i'm developping, don't worry, it is just free of charge for you.
hi do you have a unlimited sdu software for without dongle usage, if you had please give me.
cmadradi
Post by cmadradi »
It seems that everything is launched ok, but when I'm trying to install 2-SDU, 3-SDU 4.1 or 3-SDU 5.01 it asks for company name and user to verify your PIN NUMBER. It keeps telling me that it is incorrect. The hasp's drivers that the setup.exe installs should be with the dongle opened and running right? Can you help me some more? I have a lo of experience programming these panels, NFS 3030 and NFS23030 also, but I'm freelancing now.
NEW STATUS MY BAD MY BAD, The date, the bloody date... sorry man works perfectly
cmadradi
Post by cmadradi »
Does anybody has tha dongle image (*.dng) for the 2-sdu programming est2 and the xls1000? The software key lts-maroc gladly share with us only works with EST3. Please if anybody can help me that'd be great...
Serial Number : 000908
3-SDU : Enabled
> Delete Project
> Save Project
> Import Project
> Export Project
> Compile Project
> Download Project
> Import MicroCode
> Audio
2-SDU : NOT Enabled
RDU : NOT Enabled
Honeywell RDU : NOT Enabled
FireWorks : NOT Enabled
ANA-USA : NOT Enabled
ACDB : NOT Enabled
EST Specials : NOT Enabled
EST DLL : NOT Enabled
Brand : Edwards Systems Technology
hijazih
Post by hijazih »
Hi lts-maroc,
Any update regarding the emulator?
cmadradi
Post by cmadradi »
Ok, after a lot of searching and reverse engineering I was able (with a lot of help from Lomax) to remove the date problem of the DNG that was handed by lts-maroc, also I was able to remove the disabled features of all the other softwares, (fireworks, honeywell, miretone and EST2 included) here's skch eck result
Key Existance Test: Passed
Key Status Test : Passed
Key Code Test : Passed
3-SDU : Enabled
> Delete Project
> Save Project
> Import Project
> Export Project
> Compile Project
> Download Project
> Import MicroCode
> Audio
2-SDU : Enabled
> Delete Project
> Save Project
> Import Project
> Export Project
> Compile Project
> Download Project
RDU : Enabled
Honeywell RDU : Enabled
FireWorks : Enabled
> color Text software
ANA-USA : Enabled
ACDB : Enabled
> Stand alone up to 8 doors
EST Specials : Enabled
I'm glad to share with anybody, but please, please! Does anybody has the SDU.exe for programming the XLS-1000?
Thanks!
screenshot of skc eck
FVILLA
Post by FVILLA »
cmadradi wrote:Ok, after a lot of searching and reverse engineering I was able (with a lot of help from Lomax) to remove the date problem of the DNG that was handed by lts-maroc, also I was able to remove the disabled features of all the other softwares, (fireworks, honeywell, miretone and EST2 included) here's skch eck result
3-SDU : Enabled
> Delete Project
> Save Project
> Import Project
> Export Project
> Compile Project
> Download Project
> Import MicroCode
> Audio
2-SDU : Enabled
> Delete Project
> Save Project
> Import Project
> Export Project
> Compile Project
> Download Project
RDU : Enabled
FireWorks : Enabled
> color Text software
ANA-USA : Enabled
ACDB : Enabled
Thanks!
hi sent PM to trade your solution for the XLS1000 option.
regards.
cmadradi
Post by cmadradi »
Have anyone been able to run the Multikey version Dump in W7 64 bots or W8 64 bits?
Nirujan
Post by Nirujan »
lts-maroc wrote:Dear Friends,
I have a solution for you, to avoid any lose of your HASP key, you can dump the key with dongle services, or get a cracked software that can dump it and emulate it when you don't need to use the dongle key.
I leave the company that i worked for, and i use it for my own projects, for maintenances.
Good Luck.
Yassine
hi i have a est3 dongle can you help me to dump my key and without dongle programming methods also.
lts-maroc
Post by lts-maroc »
Dear Friends,
if you want to dump, you use the dongle service software(after signing in) and send it to them, they will create a DNG file witch work for 7 days.
Otherwise, try other software witch are free, like sentinel witch you search for cracked version, and do all the work by your self.
Regards.
