Siemens Desigo/Cerberus Pro
vipincharles
Re: Siemens Desigo/Cerberus Pro
Post by vipincharles »
firetruk wrote:Hi there,
Would anyone have manuals and the programming software for these systems?
U GOT IT??
remi88
Post by remi88 »
I could find the siemens MXL programing software, only runs on windows 98.
I ever programmed a MXL panel.
I just assumed that the software needed a key or something.
could someone enlighten me.
Kmaysob
Post by Kmaysob »
You will have to call in a Siemens dealer for the Cerberus pro and a Siemens corporate branch for any desigo work.
Both panels use software much like notifier does . There flat out, is no way to get it without being a dealer.
The mxl requires a permanent key from Siemens, but will be worthless unless you are a dealer . For dealer "a" to plug into a panel installed and programmed by dealer "b", would require a password of the day request by the customer. Once approved , a Siemens dealer will have to call in with the approval and take control.
The only Siemens panel that is non proprietary/open source is the fs-250.
Kmaysob
Post by Kmaysob »
remi88 wrote:I could find the siemens MXL programing software, only runs on windows 98.
That depends on the version . 10.03 & 17.02 were for Windows 98. Later versions worked with XP . We found a way around the windows 98 requirement years ago by using a dos based bootable flash.drive .
isatronix
Post by isatronix »
firetruk
Post by firetruk »
Hi there,
