EST3 to BMS communication
kantula611
Post by kantula611 »
Dear All.
I am Kan from vietnam. now i am using EST3 panel, and i want to make a connect from EST3 panel to BMS via TCP/IP, with this connect i can control and supervision EST3 panel from BMS ( Building management System ).
I find on internet i known the " EST3 to BMS communication" with FSB-FC can connect EST3 panel to BMS via TCP/IP, but it not mention how can control EST3 panel from BMS ?
Pls help me this problem.
Re: EST3 to BMS communication
I think you misunderstand what BMS is. It is a hardware device that is used to connect a rs232 serial devices via a Ethernet connect.
it is not software that you can control the EST3 panel.
junjun
Post by junjun »
Gateway device like FSB-PC is use only to monitor events coming from Est-3 panel.
what is it like a printer?
junjun
Post by junjun »
not really..gateway device like fsb-pc is a protocol converter which enables devices using est3 protocol to send information and communicate via Ethernet, Modbus and lonworks networks.
donpccc
Post by donpccc »
We've bought FSB-PC try to connect with other brands but never successful. Almost of thems down to low lever dry contact. If any one connecting success, please share everybody some advice. so SAD!!!
FSB-PC is still a mystery to me.
So, you have a EST3 you put the FSB-PC on the RS232 port of the panel, then someone writes a program like BMS?
if so is BMS the only program?
junjun
Post by junjun »
here's the link for further information http://www.fieldserver.com/products/drivers/EST3.php
donpccc
Post by donpccc »
junjun wrote:here's the link for further information http://www.fieldserver.com/products/drivers/EST3.php
Thanks for your links, let's me try first! so sad we never connection with BMS successful
donpccc
Post by donpccc »
Mr JunJun, I read your comment in title Connection with FSB-PC, i used your sample config to download the FSB-PC. Then the BMS only see the node base information, and i don't understand your config, can you help me more detail, can i sent you my file.SDU config.
