network
thinpositivex
network
Post by thinpositivex »
hi...i'm new in est3
i have a problem regarding on the network est3..based on datasheet and previous statement have state the wire
length between 3 panel is 1500 meter.how about the forth panel because i have connect three panel
and it able to communicate , if i connect the forth panel,the voltage drop and the led at tx2, rx2 sometimes steady and
sometimes off.could somebody help me regarding on this problem and why this problem happen
Re: network
com problems are usually a capacitance problem not a voltage drop problem, not saying it's not.
but check the capacitance first, the EST3 can run at 3 bauds 9600,19.2k or 38k, the slower the speed the less capacitance is a problem.
Which baud is your network running? do a download at 9600 see if it works, try 38k see if it fails.
I tried downloading a large system at 38k which runs on 19.2k and it locked up a panel ( I needed to plug into and download to unlock)
there is a post with a doc from EST about checking the RS-485 network line with a oscilloscope.
