EST3 - disabling outputs
Posted: Fri Sep 24, 2010 9:33 am
You can not disable outputs
You can disable horns/strobes
If you do not have a switch panel installed on the system make all outputs visibles/strobes
per jim m:
you CANT disable a COMMON ALARM OUTPUT. BUT , you can disable every other type of output. (THATS DISAdvantage of COMMON ALARM OUTPUT)
per jim m:
