DEVICE TYPE FOR CC1 (SOUNDER & FLASHER)
Posted: Sun May 09, 2021 3:57 am
by Maw Kuri
PROBLEM: I tried several device types' for the CC1 serving a sounder & flasher to accommodate the client's requirement that when an assigned switch on the Firemans Panel is pressed would mimic a fire scenario. The rule was just copied from a fire scenario on Zone 01, but the input event which is 'smoke alarm' was replaced with 'SW event''. When the smoke alarm in Zone 01 is active all the outputs works just fine including the sounder and flasher. But when the fire in Zone 01 is initiated by a 'SW', all other outputs would work except the sounder and flasher. Any suggestion please.
Re: DEVICE TYPE FOR CC1 (SOUNDER & FLASHER)
Posted: Thu Aug 19, 2021 11:14 am
by old_tech
Create an AND then activate it with the switch
Posted: Fri Sep 10, 2021 10:24 pm
by Maw Kuri
Thank you
