Clarification on Alarm descriptions
fahdbt94
Post by fahdbt94 »
These alarms have been constantly present on the system.
Can anyone please explain what each of these alarms means, and the best way to rectify them.
1. 01020686 Unprogrammed Device Data Card 2
2. 01020682 Map Fault Data Card 2
3. 01030677 Ground Fault Data Card 1 (Disabled Active)
4. 01000604 Internal Fault
5. 01030686 Unprogrammed Device Data Card 2
6. 01030682 Map Fault Data Card 2
7. Card 03 Database out of sync with CPU
Re: Clarification on Alarm descriptions
You need to clean up the system.
connect your Computer and fix it.
if you do not have the database or the ability to run the EST3 SDU program you can not fix it.
call an EST3 Tech.
also you have a ground on the system
