Quickstart with PT-1s printer causing ground fault
Posted: Wed Mar 19, 2014 11:11 am
by FireTech72
I have a QS1 that has a PT-1s printer installed. Every time the printer is powered, there is a ground fault on the QS panel. This just started. The printer was existing and was working normally until recently.
Is this ground fault normal when a printer is installed and it did not show up until recently? Ideas anyone?
Re: Quickstart with PT-1s printer causing ground fault
Posted: Wed Mar 19, 2014 8:26 pm
by Sam
install the IOP-3 is a isolator for RS-232.
Posted: Thu Mar 20, 2014 8:11 am
the ground fault is common.
remove the ground lug off the plug that you plug into the wall, this will fix the problem
