QS-CU help
gsmith
QS-CU help
Post by gsmith »
log into qs1 with prog cable thru rs232 retrieve starts and then stops before 50%.
Re: QS-CU help
try connecting to the power supply instead of the rj11 jack.
when I am having load problems this is the first thing I try.
also do a restart on the panel upload while it is restating
getech
Re: QS-CU help
Post by getech »
You can try to lower your baud rate communication to 4800 sometime it help
