QS - Dialer String Setup for miscellaneous Troubles
QuickStart Panel
When the Quickstart panel has a ground fault, Battery trouble, telco fail or AC loss it will only send a panel trouble to the CS unless you add these dialer strings
Adding dialer strings for Panel NAC Circuit,telco,AC fail and battery troubles
Update Device address
1.1.270 NAC output off of panel power supply
1.1.271 NAC output off of panel power supply
1.14.1 Telco Trouble Primary
1.14.2 Telco Trouble Sec.
1.15.2 Battery Fault
1.15.7 AC power fail
1.15.9 Check system wiring AKA: Ground Fault
Default CID Codes:
351 Telco 1 fault
352 Telco 2 fault
301 AC Loss
302 Low System Battery
310 Ground Fault
Navigate to:
Configure->Correlation->Device Tab->(check) Show Pseudo Points
select address, then Response Type (Trouble), click Dialer String
String
Active 130001270, Restore 330001270
Active 130001271, Restore 330001271
Active 135100000, Restore 335100000
Active 135200000, Restore 335200000
Active 130200000, Restore 330200000
Active 130100000, Restore 330100000
Active 131000000, Restore 331000000
