QuickStart - QS-CU Version 2.5 & 1.8
QuickStart - Configuration Utility
The QuickStart panel is programed via QS-CU
** Load the QS-CU2.5 on your computer you will need it sooner or later**
Both versions can ran on the same Computer. But you can use QS-CU 2.5 for all your new and older QS panels.
Under - Project configuration-> CPU Revision pick (Versions 2.5 and later or Versions prior to 2.5)
When going to a new site, always check the CPU version
You can Identify the CPU/panel type via the reports. Login with a lvl4 password, goto report -> revisions.
The CPU version will be either 1.8 or 2.5
CodeLoader v2.15 will load the CPU with 1.8
CodeLoader v2.2 will load the CPU with 2.5
QS-CU1.8 will only work with CPU1.8
QS-CU2.5 will work with both CPU1.8 and CPU2.5
If you get a new QS panel from EST it will have CPU2.5 in it, and you will need QS-CU2.5
Mirtone-1.8 - http://www.thealarmtech.com/download/ES ... ftware.rar
QS-2.5 - http://www.thealarmtech.com/download/EST/QS-CU2.5.ZIP
QS-1.8 - http://www.thealarmtech.com/download/EST/QS-CU.EXE
Mirtone QuickStart Software - http://www.thealarmtech.com/download/ES ... ftware.rar
*QuickStart - QS-CU Version 2.5 & 1.8
- QS Ver2.5 Release Notes.pdf
- (203.43 KiB) Downloaded 4248 times
Re: *QuickStart - QS-CU Version 2.5 & 1.8
d you by chance have the 2.5 version of mirtone QS ?
I only have 1.8 I do not think there is a 2.5 for mirtone
there isa newer version to my knowledge. we have done an aquisiton and took over 2 of thse panels the tech from the installation company said we needed to get 2.5 version however i have yet to try 1.8 on the panel it was installed about 2 years ago next time i am there i will see what revision the panel is and do more home work on the software version. however if anyone comes across a link for the mirqs-cu 2.5 i would really appreciate it
Is it possible to have QS-CU 2.6 program on the forum so we can download it?
Awesome Thanks!!
hey Leo
Im still looking around for Mirtone Mirqs-cu 2.5 but so far no luck if you can see if anyone on the forum has a copy and post to this link it would be so helpful i have a few accounts we took over and just simply need to change some devices. let me know what you come up with. Thanks in advance
Sir Leo,
Besides this QS-CU2.5, is there another software available for these panels like a diagnostic/repairing software? Thanks
I have never seen any thing else, But the QS software does have a maintenance and diagnostics tab.
sir Leo, is there a release version of this QS-CU Software that asks for a serial key?
