** EST3 Rules editor upgrade - Notepad++ VERY COOL
This is a very Cool text editor for the EST3 SDU rules.
It will help you write rules by adding color and bold text
It will also help reduce typos
ie:
[SW 1-1-2 MANUAL PAGE LORISE SPKS ON]
SW 'PANEL1.1_SW2_*' :
ON -LOW SUP '*Lorise*SPEAKER*PAS_LVL_ALL*'';
Download the pdf to get a quick look.
If you like, install NotePad++ then follow directions for sharing MY DEFINED LANGUAGE.
download (notepad++ est3 sdu settings session.zip)
set it as your default rule editor, under LANGUAGE pick EST SDU
How can I share MY DEFINED LANGUAGE (or my syntax highlighting) with the others?
Follow the instructions below:
1. Type %APPDATA%\Notepad++ in Run box, then Enter, and a folder will open.
2. In the opened window you'll find a file named userDefineLang.xml. Copy it.
3. Do procedure 1. on the destination PC. Copy the userDefineLang.xml into the opened folder.
4. Relaunch Notepad++ from the destination PC et voila.
For sharing the syntax highlighting, follow the same procedure but replace userDefineLang.xml by stylers.xml.
http://notepad-plus.sourceforge.net/uk/about.php
Website: download.com
http://download.cnet.com/Notepad/3000-2 ... d=11014880
PROJRULE.TXT.pdf
made with notepad++
(17.84 KiB) Downloaded 3016 times
Notepad++ with EST3 SDU user defined
(10.29 KiB) Downloaded 3131 times
PROJRULE2.TXT.pdf
made with notepad++
(34.54 KiB) Downloaded 2830 times
icyangle
Re: ** EST3 Rules editor upgrade - Notepad++ VERY COOL
Post by icyangle »
yeah,i have tested it,it is very cool.
Larry
Post by Larry »
Anyway if you need to download Notepad++ I just made it here https://yumdownload.com/notepad no problems. After that, I was able to quickly edit the code and find the necessary DIV and class in my code, in general, when studying CSS, I was interested in.
fire4larm
Post by fire4larm »
How about Jens editor? Have you tried?
unzip it in C:\ ( make it default in Options -> Customize -> Configuration uncheck "Use Default..." and browse to C:\Jens editor\jfe.exe)
Jens editor.exe
(849.45 KiB) Downloaded 2575 times
