Terminal Mode / HYPER-TERMINAL - tips
Re: Terminal Mode / HYPER-TERMINAL - tips
report panel Version
command-- R=1 V
returned-- N-1000-3 V8.07.01
WORKING IN HYPER-TERMINAL
Setups for HyperTerminal - 9600db, Flow control-None
Stop comm server
N-485-PCI/BOX - sw 6 on (All switches ON) - 9600db, Power cycle BOX
Testing the comm port
- Shorting pins 2&3 out of the computers 9 pin connector will echo what you type.
- If its a C-100 you can jumper it back (check post:C-100 Manual)
N-485-PCI/BOX
Hyper Terminal will display this on power cycle of BOX
Port 0 initialized.
TESLA Master V1.4.0 System Reset.
P0000000000000000000000000000000
B1000000000000000000000000000000
Always start with a space
M=1 R - ubuffer panel 1
R=1 C - REPORT CARDS
R=1 T - REPORT TIMEZONES
Add Card
C=1 22247 1 1 2
C=panel card timezone rd1 rd2
01-01 MO 03:48
RD#01 22247 - (READER #1)
01-01 MO 03:49
RD#01 X 22247 - (The X means READER #2)
Crtl-A 0 M
NODE MAP
00000000001111111111222222222233 - address 10's
1234567890123456789012345678901 - address 1's
AAAPPP
